UPS
I need a decent UPS. Something to keep my PC and Modem/Router online when I loose power.
I'd love it if it has some sort of either remote management for notifications, or SSH. Not sure where to begin looking.
7/27/2026
How to get true SSH management without blowing your $2k budget⚡
Hey Rick, you are in a really specific middle-ground here. If you just ask for a "decent UPS," most people will point you toward a standard unit that uses a basic USB cable plugged into your PC. The problem? If your PC freezes, updates, or shuts down, your remote management dies completely.
To get true SSH and independent network alerts directly from your router, you need a "prosumer" unit with an expansion slot to plug in a dedicated Network Management Card. You absolutely do not need to spend $2,000 to get this.
(And just to clear up a very common point of confusion: Yes, all of these units come with heavy-duty internal batteries already installed right out of the box. You plug them in, and they are immediately ready to provide backup power!)
Here are 3 excellent, complete solutions available on Newegg right now. Each option pairs a base UPS with the exact network card you need:
Option 1: The 1000VA Pure Sine Wave Standard (Estimated Total: ~$727)
The APC Smart-UPS SMT1000C series offers bulletproof, enterprise-grade reliability and seamlessly accepts an AP9640 network card into its SmartSlot to unlock your true SSH requirements.
- the Base UPS: (~$556)
- the Network Card: (~$171)
- Why it fits: APC is the legendary industry standard for IT server rooms. It gives you the "pure sine wave" power that modern PCs crave, and its long-term build quality is unmatched. This 1000VA capacity is perfect for a standard PC and router.
Option 2: The 1500VA Heavyweight Upgrade (Estimated Total: ~$886)
The APC Smart-UPS SMT1500C packs the exact same premium features and SSH capabilities as Option 1 but scales the battery up to handle massive power draws.
- Base UPS (~$715)
- Network Card (~$171) same network card which is used in option 1
- Why it fits: If you have a massive multi-monitor setup or a heavy workstation pulling maximum watts, this guarantees you won't be rushing against the clock to save your work when the power cuts out.
Option 3: The Slim 1500VA Pick (Estimated Total: ~$956)
The CyberPower OR1500LCDRM1U natively supports the RMCARD205, making it a highly space-efficient way to get independent SSH control.
- Base UPS (~$615)
- Network Card (~$341)
- The Catch: It uses a simulated sine wave instead of a pure sine wave. This is totally fine for most electronics (like modems and routers), but pure sine wave is generally the gold standard for high-end PCs.
My Personal Pick:
If I was grabbing one of these for my own rig to keep my system safe during a sudden grid drop, I would absolutely pull the trigger on Option 2 (The APC SMT1500C). It hits the perfect sweet spot of giving you incredibly clean pure sine wave power, legendary reliability, and the exact SSH network control you want, all while leaving well over $1,000 left in your budget.
Note: Don't overspend on a massive server rack battery! Grab one of these base units and the matching network card, and you will have a flawless, out-of-the-box SSH setup well under your limit.
| Item | Price |
| APC SMT1000C Smart-UPS, Line Interactive, 1000VA, Tower, 120V, 8x NEMA 5-15R outlets, SmartConnect Port+SmartSlot, AVR, LCD | $555.99 as of Jul 27, 2026 |
| Apc By Schneider Electric Ap9640 Ups Management Adapter | $379.99 as of Jul 27, 2026 |
| APC SMT1500C Smart-UPS, Line Interactive, 1500VA, Tower, 120V, 8x NEMA 5-15R outlets, SmartConnect Port+SmartSlot, AVR, LCD | $721.99 as of Jul 31, 2026 |
| CyberPower OR1500LCDRM1U Smart App LCD UPS Systems - 1500VA/900W, 120 VAC, NEMA 5-15P, 1U, Rackmount, 6 Outlets, LCD, PowerPanel | $614.95 as of Jul 27, 2026 |
| CyberPower RMCARD205 Remote Management Card - Black | $340.95 as of Jul 27, 2026 |
| TOTAL | $2,613.87 |
7/29/2026
Eaton 5PX G2 1500VA UPS + Network-M3 Card
Product Overview: Eaton 5PX G2 1500VA UPS + Network-M3 Card
Key Specifications
- Power Capacity: 1500 VA / 1440 W (Unity / Near-Unity Power Factor)
- Topology: Line-Interactive (Pure Sine Wave)
- Form Factor: 2U Rackmount / Convertible Tower
- Included Management: Eaton Gigabit Network Card (Network-M3)
- Outlets: 8x NEMA 5-15R (including switchable load segments for remote rebooting)
- Approximate Retail Price: ~$1,250 – $1,450
Remote Management & Security Capabilities
1. Native SSH & CLI Management
- Direct command-line interface (CLI) administration over SSH for terminal-based scripting, monitoring, and remote configuration.
- Eliminates reliance on web-only interfaces or local USB daemon connections.
2. Advanced Notification & Alerting System
- SMTPS Email Alerts: Sends immediate notification logs during power events (grid loss, low battery, overloads, temperature thresholds).
- SNMPv1 & SNMPv3 Support: Easily integrates into network management platforms (PRTG, Zabbix, Nagios, SolarWinds).
- Syslog & MQTTS: Streams real-time telemetric event logs directly to your centralized SIEM or home automation servers.
3. Cybersecurity Certified Network Card (Network-M3)
- Certified under UL 2900-1 and IEC 62443-4-2 cybersecurity standards.
- Secure boot, zero-trust hardware architecture, and HTTPS/TLS 1.3 web management encryption.
4. Automated & Graceful System Shutdown
- Pairs with Eaton Intelligent Power Manager (IPM) software over your local network to execute safe, unattended shutdowns for PCs, NAS drives, and hypervisors before the battery depletes.
7/23/2026
Finding the right…
Finding the right Uninterruptible Power Supply (UPS) with advanced remote management capabilities requires stepping out of basic consumer models and into enterprise or "smart" territory. To get features like native SSH access, SNMP protocols, or detailed email/network notifications, you need a UPS that includes or supports a Network Management Card (NMC).
With a budget between $500 and $2,000, you can secure top-tier power protection for your PC and networking gear on Newegg. Here are the best recommendations tailored for you:
The Premium Enterprise Choice
If you want industry-standard infrastructure that offers deep command-line flexibility and native security, this is the gold standard configuration.
APC Smart-UPS Battery Backup and Surge Protector
₹204,880.00·APC
4.9(22)
The APC Smart-UPS Battery Backup and Surge Protector line is legendary for reliability, offering a pure sine wave output which is essential for modern PC power supplies. To achieve SSH capability, you pair the UPS with an APC Network Management Card 2, keeping the total price well within your budget.
Why it fits: The dedicated management card unlocks a secure external command line interface (CLI via SSH) supporting up to 2048-bit encryption. It allows you to script shutdowns, review precise event logs, and receive detailed mobile or email notifications the second your home loses power.
Newegg+ 1
The All-In-One Value Choice
If you want remote management ready out of the box without buying an extra internal network card, this option offers spectacular integration features.
CyberPower Smart App Sinewave UPS
₹82,146.00·CyberPower
4.5(26)
The CyberPower Smart App Sinewave UPS provides robust 1500 VA capacity alongside advanced Automatic Voltage Regulation (AVR) to keep your PC and modem steadily powered during brownouts or complete blackouts.
- Why it fits: It features native SNMP/HTTP remote monitoring protocols right out of the box. Through its multifunction LCD panel and network integration, you can easily establish remote alerts, monitor real-time battery runtime, and manage network-based power configurations directly from a secure web portal.
7/25/2026
Before making any decisions and getting best option available We need to know what is the wattage of your psu depending upon how long you want your pc to be online after power cut and opting for simulated wave or pure sine wave then adding wattage depending upon the router you currently own
8/1/2026
CyberPower CP1500PFCLCD
This is probably the sweet spot for a home PC + networking setup.
https://www.newegg.com/p/pl?d=CyberPower+CP1500PFCLCD+PFC+Sinewave+UPS
8/5/2026
This is what you need.
APC SRT2200XLA Smart-UPS On-Line
